Activity › Forums › Adobe Premiere Pro › Why do I have sharp timeline playback output, but slightly softer “parked” timeline output?
  • Why do I have sharp timeline playback output, but slightly softer “parked” timeline output?
    Posted by Mel Matsuoka on January 15, 2014 at 4:23 am
    I’ve been noticing that my 1080p23.98 ProRes HQ timelines are playing back at full quality, with sharp graphics (graphics that are are baked-in to ProRes HQ Quicktime files, that is), but as soon as I hit stop, the image goes slightly soft. This is more noticeable when there are graphics on the clip, but it doesnt matter if the graphic is a generated Premiere title, or if the graphic has been baked into the clip as a render out of After Effects.
    The Viewer quality setting is set to “Full”, and there is no scaling or anything that requires rendering in the timeline…just simple AE-rendered ProRes clips.
    It’s not a showstopping problem, but it’s noticeable enough to be totally annoying, esp. when tweaking graphics with a client looking over your shoulder.
    I’m seeing the difference in sharpness in both the Premiere Program viewer window, as well as my external Plasma, being fed the 1080 signal through a Decklink 4K Extreme card.
    Any ideas?
    Mel Matsuoka replied 12 years, 8 months ago 2 Members · 2 Replies
  • Tero Ahlfors
    January 15, 2014 at 8:34 am
    What is your paused resolution?
  • Mel Matsuoka
    January 15, 2014 at 8:50 pm
    [Tero Ahlfors] “What is your paused resolution?”
    Ahh, that was it! I totally forgot about that option! Thanks for the tip.
