Activity › Forums › Apple Final Cut Pro Legacy › Why do “custom window layouts” reset occasionally?
  • Why do “custom window layouts” reset occasionally?
    Posted by Kevin Ferias on August 24, 2012 at 3:05 pm
    I have two Mac Pro/FCP systems (2 locations) and have used FCP for 8 years now with 3 different G5 machines over the years and it never fails, every two or three launches, FCP opens in the default window layout- I then have to go to the Window/Arrange menu to change it back to my custom layout. Why does the system do this? Even when I choose my pre-designed & saved layout, forget about the Effects window- it never opens with the rest of the window layout and I must manually open it and size/place each time.
    So all tolled, FCP launches with my custom layout only about 60% of the time. It’s just annoying!
    Any advice on what is happening or what I am doing incorrectly when saving my own window layouts?
    Thanks for your help!
    Kevin
    2 G5 Mac Pros (also did it w/ my Power PC)
    FCP 7.0.3
    Kevin Ferias replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
