Activity Forums Apple Final Cut Pro Legacy why do clips need to re-render w.TL move
  • why do clips need to re-render w.TL move
    Posted by Chris Gorman on May 9, 2009 at 9:15 pm
    I’m editing a sequence with mixed source footage, eg., ProRes clips (from hdv), and dv footage. My sequence is set for NTSC DV 3:2
    Why do all the clips need to be re-rendered every time I simply move the clip on the TL. For example, with everything already rendered, a ripple edit or anything that changes the position of the clips along the TL, all the clips need to re-rendered.
    PowerPC G5 DP2.3, 4GB DDR SDRAM, ATI X800XT, OSX.4.11, QT 7.5.5, FCStudio2, FCP 6.0.5 Sonnet 5 Bay SATA (RAID or JBOD as needed), ACD 23″ & Sony NTSC Monitor via Matrox v.1
    Sony ZIU hdv, edit w.ProRes
    Chris Gorman replied 17 years, 4 months ago 2 Members · 2 Replies
  • Walter Biscardi
    May 9, 2009 at 10:26 pm
    Any clip that does not match your timeline will have to be re-rendered every time it moves. This is why many of us convert all the footage to one format during ingest.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Chris Gorman
    May 9, 2009 at 10:42 pm
    Thank you. I wonder what the quality difference is between downcoverting hdv via firewire on the way in, vs. taking a pro res clip from the TL, exporting as QT sc movie and re-importing…or if there’s some other down side to that.
