Activity Forums Apple Final Cut Pro Legacy Why converting uncompressed SD video to ProRes flips the field dominance to upper?
  • Why converting uncompressed SD video to ProRes flips the field dominance to upper?
    Posted by Jeff Cotten on January 6, 2012 at 7:41 pm
    When I convert a SD video file to ProRes 422 using compressor, it outputs a file that is upper field first. The uncompressed file is lower field first. I checked the “Frame Controls” setting in compressor and it is set to “Same as Source”. Thanks for any info.
    Jeff Cotten replied 13 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    January 6, 2012 at 8:04 pm
    HD video is upper field…SD is lower field.
    Shane
    Little Frog Post
  • Jeff Cotten
    January 6, 2012 at 8:25 pm
    Yes – it’s changing the SD video to upper field. It’s not keeping it lower field for SD.
  • Shane Ross
    January 6, 2012 at 8:47 pm
    Ohhhh…you are making it ProRes SD? And it is switching the field order?
    Shane
    Little Frog Post
  • John Pale
    January 6, 2012 at 8:48 pm
    What is your SD frame size ?
    720 x 480 or 486?
  • Jeff Cotten
    January 6, 2012 at 8:55 pm
    It’s 720 x 486. Would that make a difference even if it was 720 x 480?
  • Ian Liuzzi-fedun
    October 12, 2012 at 4:03 pm
    Any answer on this?
  • Jeff Cotten
    October 12, 2012 at 4:33 pm
    No. I still don’t know what’s happening in this processs.
    This is happening to you too?
