Activity Forums VEGAS Pro Why can’t PluralEyes sync camera footage with an audio recorder?
  • Why can’t PluralEyes sync camera footage with an audio recorder?
    Posted by John Rofrano on November 25, 2012 at 2:08 pm
    OK, it’s time for you guys to help me! 😀
    I downloaded a trial of PluralEyes to see if it would help my workflow. I usually shoot long events like plays, live bands, or other performances and record my audio directly from the mixing console with my Marantz PMD-660 audio recorder. What I then have to do is sync the audio recorder with my camera footage and as anyone who has tried this without genlock knows, the two devices will drift over time so you have to split your audio recording up and continue to re-sync it every so often.
    I thought PluralEyes might do this automatically so I split my audio recording at 10 minute intervals, select all of my footage and audio and ran PluralEyes, I even told it the events were in chronological order.
    This is what my timeline looked like BEFORE:
    Unfortunately, This is what my timeline looked like AFTER:
    OK, what did I miss? It didn’t sync anything!!!
    Your help will be graciously appreciated. 🙂
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
    Timothy Evans replied 13 years, 8 months ago 12 Members · 39 Replies
  • 39 Replies
  • Graham Bernard
    November 25, 2012 at 2:41 pm
    If I used PE, I’d be all over for you!
    Next time . . . . .
    G
    Cameras: Canon XF300 and two elderly XM2s
  • Theo Van laar
    November 25, 2012 at 3:30 pm
    It looks like the amplitude of the upper audio track is much bigger then the amplitude from the lower audio track. My experience is that this sometimes confuses plural eyes. What helped me in those cases is not synchronizing all the short clips at the same time with the longer audio events but only a few each time. Just see if that helps for you.
    Theo
  • Dan Thompson
    November 25, 2012 at 3:32 pm
    John, did you stop and start the camera during the event? If you did and the audio kept recording, you’ll probably need to split the camera event everywhere that it stopped and started, then rerun PE, and cut out the extra. This is what I have done, someone else may know a better way, but this works for me. Hope it helps, Dan
  • John Rofrano
    November 25, 2012 at 4:07 pm
    [Dan Thompson] “John, did you stop and start the camera during the event? If you did and the audio kept recording, you’ll probably need to split the camera event everywhere that it stopped and started, then rerun PE, and cut out the extra.”
    No the camera ran continuously except for having to change the tape after one hour. That’s why there are only two camera events. This was a 2 hr play with the camera and audio running continuously.
    ~jr
  • John Rofrano
    November 25, 2012 at 4:11 pm
    [Theo van Laar] “What helped me in those cases is not synchronizing all the short clips at the same time with the longer audio events but only a few each time. Just see if that helps for you.”
    I tried just selecting the first camera event and the first audio event and I had already synced them by hand. PluralEyes moved them way out of sync and interesting, it moved the camera event which is NOT what I want.
    Is there any way to tell PluralEyes that the camera is the master and the audio is the slave I’m trying to sync? I don’t want the camera events moved at all.
    Perhaps it simply wasn’t designed to sync audio with video. 🙁
    ~jr
  • John Rofrano
    November 25, 2012 at 4:22 pm
    [Theo van Laar] “It looks like the amplitude of the upper audio track is much bigger then the amplitude from the lower audio track. “
    You know, it is possible that the audio from the camera is too muddy to be synced. There is a lot of room echo/reverberation because it’s in an auditorium while the audio from the mixer is clean and dry. It may just be too different given the reverb/dry mix. Even though I can hear the words clearly, the human brain can filter the human voice much better than a computer program ever could.
    I was really hoping this would work too. 🙁
    ~jr
  • Michael Acres
    November 25, 2012 at 4:25 pm
    Tell it to try really hard(its an option)
    Try not splitting the audio file
    Try not telling it they are in chronological order
    Try splitting the video files into a couple segments instead of audio
    my guess is that your audio files plays slightly slower than your video files and the ‘drift back is confusing PE.
    FYI it has been my experience that audio feeds run a frame or 2 longer per 30minutes than my video capture but I only know that to be true for the cameras and gear I use
  • Theo Van laar
    November 25, 2012 at 4:55 pm
    If the audio from the camera is ‘too muddy’, you can still try the TRY REALLY HARD option. This might do the trick in your case.
    Theo
  • John Rofrano
    November 25, 2012 at 5:12 pm
    [Shoestring Videos] “Tell it to try really hard(its an option)
    Try splitting the video files into a couple segments instead of audio”
    I tried everything but nothing worked. I even added media markers and turned on the option to use them and it still gave the same results.
    I’ve wasted more time at this point than it would have taken me to sync the audio by hand (usually only a 15 – 20 minute job) so I’m guessing that PluralEyes cannot help my workflow. 🙁
    Thanks everyone for all the suggestions. I guess my audio is too different between camera mic and console mix for PluralEyes to it figure out. (on the bright side I saved $200)
    ~jr
  • John Rofrano
    November 25, 2012 at 5:15 pm
    [Theo van Laar] “If the audio from the camera is ‘too muddy’, you can still try the TRY REALLY HARD option. This might do the trick in your case.”
    Tried that. No go. I think the reverberation of the auditorium is throwing it off.
    Maybe they need a Try really, really, really, hard mode. 😉
    ~jr
Page 1 of 4
