Activity › Forums › Apple Final Cut Pro Legacy › Why can’t I use the Edit-Undo function
Posted by Austin Steele on March 12, 2009 at 10:22 pmI am working on a new project and it wont let me use the undo function (Edit-Undo or Apple + Undo)
Why is this? Its a very use full command. Thanks!
Marianna De nadal replied 15 years, 9 months ago 4 Members · 4 Replies -
David Bogie
March 13, 2009 at 4:34 pmHas undo EVER worked for you in previous projects?
There’s only one reason undo won’t work, you haven’t done anything to undo.
Maybe two reasons. you’ve set the prefs to 0 levels of undo.
Okay, three reasons. FCP is broke.bogiesan
Russell Lasson
March 13, 2009 at 4:43 pm[david bogie] “There’s only one reason undo won’t work, you haven’t done anything to undo.
Okay, three reasons. FCP is broke. “Fourth reason, the “Z” on the keyboard could be broken from using apple+z too much.
-Russ
Russell Lasson
Universal Post
Ridgeline Digital Cinema Mastering
Salt Lake City, UT -
Austin Steele
March 13, 2009 at 5:45 pmha thanks for the suggestions. Its magically working now. Thanks for the help
