Activity Forums Adobe Premiere Pro Why can’t I rename?
  • Why can’t I rename?
    Posted by Ben Mears on May 13, 2009 at 10:08 pm
    Has anyone else noticed problems with renaming in Adobe Premiere Pro CS4?
    It’s really weird because some things will be nameable and some things for not.
    For example, I click one time on the name of a sequence and the white box appears around the channel box but the word itself is not highlighted and the cursor icon does not appear so I cannot change the name. Right clicking and selecting “Rename” from the list also does nothing at all.
    Then I repeat the exact same process on a different sequence or bin and the word highlights as it should and I get the cursor icon, enabling me to, in fact, change the name.
    This is obviously a bug and I’m wondering if anyone else has experienced this or has any solutions. Needless to say, it’s getting pretty difficult to work with names such as “Bin 147” or “Sequence 1 Copy Copy Copy Copy Copy Copy”.
    Thanks.
    -Ben
    Jon Barrie replied 16 years, 9 months ago 5 Members · 7 Replies
  • 7 Replies
  • Eddie Lotter
    May 13, 2009 at 10:39 pm
    This is a known issue.
    Widen the clip name column and you will be able to rename properly.
    Cheers
    Eddie
  • Ben Mears
    May 13, 2009 at 11:22 pm
    Awesome! Thanks for the solution!
  • Eddie Lotter
    May 14, 2009 at 1:11 pm
    [Ben Mears] “Awesome! Thanks for the solution!”
    You’re welcome. Happy editing.
    Cheers
    Eddie
  • Randall Martin
    May 22, 2009 at 12:03 am
    Another thank you!
  • Eddie Lotter
    May 22, 2009 at 12:18 am
    [randall martin] “Another thank you!”
    You’re also welcome. I’m sure it will be fixed in the 4.1 update due out soon, but at least there is a workaround. 🙂
    Cheers
    Eddie
  • Russell Belleret
    December 9, 2009 at 8:21 am
    Solved it..!! Thanks *3 ..Just installed the update but the nuisance remains.
  • Jon Barrie
    December 9, 2009 at 11:45 am
    With a clip highlighted in the project panel you can open the rename by hitting return key.
    – Jon Barrie
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
