Activity › Forums › Adobe Audition › Why can’t I modify the 2 sec silence???!
  • Why can’t I modify the 2 sec silence???!
    Posted by David on May 11, 2005 at 11:48 pm
    Hello,
    I’m trying to burn a CD Mixed down project from the session window and modify the 2 second fade down/fade up silence between each track to no break (it’s a speaker.)
    PROBLEM: I click on custom and the 2 second and time box are grayed out—I can’t select them???
    What’s going on?
    Thank you , as I’m perplexed.
    David
    Willie Toth replied 21 years, 4 months ago 2 Members · 1 Reply
  • Willie Toth
    May 12, 2005 at 12:48 am
    David,
    Personally I just add or delete the amount of silence I want either by highlighting the silence at the begining of the track on the edit side, right click and cut … If you want to add silence, on the edit side go to generate>silence … For writing audio to CD I use Nero and there is a box you can check if you don’t want any breaks between tunes …….. WILLIE
