Activity Forums Adobe After Effects Why can’t I loop a composition in After Effects?
  • Why can’t I loop a composition in After Effects?
    Posted by Dinenna on March 1, 2007 at 1:37 pm
    I have a 4 minute composition created in After Effects that I need to loop… can this be done?
    Any help is greatly apprreciated!!
    Anthon replied 19 years, 5 months ago 3 Members · 2 Replies
  • Kuaishou
    March 1, 2007 at 3:34 pm
    yes if every layer in your composition has the same end keyframe as the first keyframe(ie the same parameters)…then join your first composition with a duplicate composition minus 1 frame in the begining of your 2nd duplicated composition…or u can use an expression…cheers…merv
  • Anthon
    April 1, 2007 at 9:19 pm
    1. Expressions;
    a) apply Time Remapping to the nested comp
    b) select the Time Remap keyframes, and apply expression: Property > loopOutDuration.
    2. render out a proxy of the nested comp, and loop this. will loop faster and more efficient for preview, but still has to be overridden when rendering out final version.
    if anyone has another way, please let know! weird limitation, for which I cannot see a reason.
