Activity Forums Apple Final Cut Pro Why can’t I layer (using blend modes) more than 2 tracks of video without issues?!?
  • Why can’t I layer (using blend modes) more than 2 tracks of video without issues?!?
    Posted by Andy Milam on August 1, 2012 at 3:48 pm
    I have a projects with many video tracks layered on top of each other.
    I use different blend modes, but mostly just set to add.
    Sometimes the transitions are fine.
    But mostly right at the beginning of a new track of video it cuts in when it should be smooth transition.
    Any thoughts as to why this is happening?
    Screen Recording:
    https://reels.creativecow.net/film/fxp-x-layering-video-issue
    Andy
    Jeremy Garchow replied 14 years, 1 month ago 4 Members · 5 Replies
  • Jason Jenkins
    August 1, 2012 at 5:32 pm
    What are your system specs? Have you tried setting playback to “better performance” to see if that makes a difference?
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
    Check out my Mormon.org profile.
  • Jacob Lanum
    August 1, 2012 at 6:23 pm
    I have the same problem, occurs after render too. No solution found
  • Andy Milam
    August 1, 2012 at 6:26 pm
    Not the issue, but thanks for the reply.
    Andy
  • Andy Milam
    August 1, 2012 at 6:28 pm
    thanks.
    Some say you can just keyframe opacity (haven’t tried yet), but then you’re limited to dissolve only.
  • Jeremy Garchow
    August 1, 2012 at 7:55 pm
    Compound the clip(s) first.
