Activity Forums Adobe After Effects why can’t i import my png sequence?
  • why can’t i import my png sequence?
    Posted by Sophie Watson on January 30, 2007 at 7:13 pm
    I have a flash project (made in flash 8) of about 5800 frames and exported as png sequence.
    For some reason when i select the whole lot of files it won’t import into After Effects.
    Tried both to import both as multi frame and frame with the box “import as sequence” selected.
    but i can import a sequence of about 200 PNGs. this is no good cos i have to color correct it as a single sequence.
    thank you for your help..
    Will Coles replied 10 years, 3 months ago 2 Members · 1 Reply
  • Will Coles
    June 14, 2016 at 8:35 pm
    Old post, but Edit/File Preferences/import. Change that to 24 or 30 fps
