Activity Forums Blackmagic Design Why can’t I get playback or pass-through with the Shuttle 2?
  • Why can’t I get playback or pass-through with the Shuttle 2?
    Posted by Adam Claude jones on November 14, 2012 at 8:16 pm
    I have no idea why, but I can’t for the love of God get playback or pass-through to a HDMI monitor from my Hyperdeck Shuttle 2. This is already the second Hyperdeck I try, but nothing! I know you’re supposed to press Stop to switch between playback and recording, but I can’t get any signal at all out of the HDMI. I have tried different cables and different monitors. I get nothing. One of the monitors gave me some warning saying the signal was out of range. But the other two monitors I tried do nothing. Anybody has any idea? Is it possible that 2 Hyperdeck have defective HDMI ports?
    by the way, a little off topic but since Prores support was announced today, is there any advantages over DNxHD if you are on PC? I have been recording to DNxHD.
    Thanks.
    Adam Claude jones replied 13 years, 9 months ago 2 Members · 4 Replies
  • Adam Claude jones
    November 20, 2012 at 8:58 am
    Nobody has had this problem? Nobody from Blackmagic cares to reply?
  • Chris Pearse
    November 21, 2012 at 1:02 am
    Hi Adam,
    Which video format are you recording? The ‘out of range’ message on the one monitor would suggest that the video format you are recording is not supported on that monitor. It’s also quite likely to be the same issue with the other two monitors.
    I’ve seen the same problem with the mid-progressive 1080 formats (1080p24/25/30) many times before. If you are using these I would suggest making sure the monitors support them. These aren’t always supported on all monitors. If you need further help, please do contact technical support in your region using the numbers on the page here.
    Chris Pearse
    Blackmagic Design
  • Adam Claude jones
    November 21, 2012 at 8:23 am
    Hi Chris,
    Thanks for finally replying. I’m recording 24psf from a Panasonic AF100.
    Funny thing is that the very same monitors work with the AF100 if I plug it directly to the camera’s HDMI port. So can it really be the format?
  • Adam Claude jones
    November 29, 2012 at 10:56 am
    The silence from Blackmagic is strange.
