Activity Forums Adobe Premiere Pro Why can’t I export h264 upper field first anymore?
  • Why can’t I export h264 upper field first anymore?
    Posted by Duke Eastwood on February 1, 2023 at 1:54 pm
    Long story short;
    I work for a client… many of the videos I edit are older and are interlaced.
    Many of his older edits of his videos ARE exported h264 and ARE interlaced (they LOOK like that source footage motion wise, bringing up the meta data in Premiere or resolves shows that indeed the EXPORTED h264 file is “upper field first”)
    SO WHAT HAPPENED?
    I’ve searched far and wide on the internet and no one seems to notice that this option went away, or they think you never COULD export h264 interlaced… I HAVE THE FILES TO PROVE YOU COULD… they were exported from premiere and they were exported by people who aren’t pros…. so it’s likely premiere itself simply matched the source for the timeline AND the export… so what changed? I want to be able to export interlaced to maintain the interlaced motion of the sourced files… wanting everything under the sun to be progressive is 15 years ago; people are moving back towards WANTING that hyper real look, hence 60 fps becoming a trend… I could get that WITH the interlacing present in the footage… IF PREMIERE WOULD LET ME EXPORT UPPER FIELD FIRST .mp4 files like it seemly used to!
    Anyone know anything about this?
    Duke Eastwood replied 3 years, 2 months ago 3 Members · 4 Replies
  • Eric Santiago
    February 2, 2023 at 2:21 pm
    Have you tried AME?
    When you select anything other than Progressive under Field Order you can see both Upper/Lower options.
  • Ann Bens
    February 2, 2023 at 7:00 pm
    Match source will do the trick.
  • Duke Eastwood
    March 30, 2023 at 5:00 am
    What I found is Premiere can do it but it’s very fussy about whether or not it will even allow you to export interlaced (upper field first), because I use a template sequence with a common intro and outro they make it not possible… if I use interlaced footage to make a sequence, only then will it actually allow an upper field first export, regardless or me changed the sequence settings to interpret the sequence as upper field first.
  • Duke Eastwood
    July 19, 2023 at 5:46 pm
    Here’s an update:
    The reason Premiere can’t export interlaced from my interlaced footage is because when you make the timeline 4k it will no longer allow the footage to be maintained in the original upper field first setting. Stretching 1080i footage into a 4k timeline will necessitate a progressive scan from Premiere that you can’t change.
