Activity Forums Apple Final Cut Pro Legacy Why can’t doesn’t my widescreen video export properly?
  • Why can’t doesn’t my widescreen video export properly?
    Posted by Sally Obrien on June 6, 2010 at 7:04 pm
    I shot a video on my SD DVX100 in widescreen format.
    I probably digitized the footage incorrectly, because I didn’t change the FCP settings to anamorphic when I brought the footage into my computer.
    I’ve edited the piece, and keep trying different ways to export so that it plays at full screen. Right now there’s always a black box around it, and never fills up the whole screen.
    What am I doing wrong? I tried different things like changing FCP Audio/Video sequence settings to “DV NTSC 48khz Anamorphic”.
    When I export it as a quicktime I change my settings as well to “DV NTSC 48 khz Anamorphic”.
    Similarly when I export to DVD using compressor, I use the settings to “Mpeg2 High quality Encode Widescreen”.
    All of these always give me the same outcome: a video that won’t play at full screen. I don’t have to go back and redigitize the footage, do I?
    Much appreciation for any help!
    Sal
    John Fishback replied 16 years, 2 months ago 2 Members · 1 Reply
  • John Fishback
    June 6, 2010 at 7:48 pm
    What are your sequence settings? Sounds like the pixel aspect ration may be set incorrectly.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
