Activity › Forums › Maxon Cinema 4D › why can not select polygons or points on this file
Posted by Mauricio Barrientos on April 2, 2005 at 6:29 pmHi.
why I can not select poligons and point onthis file please ??
here is the file.zip
https://www.mbguia.com/fotosforos/problema2.zip
Mauricio Barrientos replied 3 years, 1 month ago 3 Members · 4 Replies -
Brian Jones
April 3, 2005 at 2:57 amDon’t know. I can select the polys and points. Something simple maybe? Are you using the Live Selection tool? Are you in point and/or poly mode? Computer possessed by gremlins… 🙂
Mauricio Barrientos
April 3, 2005 at 3:53 amjejej
now works.
just select the middle scare on object.
and is fixed
thanks a lot -
Jeff Andrews
April 3, 2005 at 6:35 amAs I mentioned to you elsewhere, the reason is because the red x-axis arrow is yellow in your scene, which means you have it locked (by double-clicking it earlier). That restricts you to the x-axis. Double-click in an empty area of the view to unlock it.
Regards,
Jeff Andrews
Chrome City Studios -
Mauricio Barrientos
July 27, 2023 at 12:58 pm17 years later happens again … but now on cinema 23.
i fixed on live selection …… properties by select :
tolerant edge.
thanks
