Activity Forums Avid Media Composer Why Avid MC 8 consolidates audio files when I choose copy all?
  • Why Avid MC 8 consolidates audio files when I choose copy all?
    Posted by Brigitta Bacskai on August 11, 2016 at 10:42 am
    I’ve been using MC for many years , I always chose the same method for making AAF for post sound: Include audio, all tracks, use marks, use selected tracks, aaf edit protocoll, copy all media, same folder as aaf. It always worked with MC 7 and previous and now, with 8 it keeps consolidating the audio files to 60 frames.
    Does anyone have any solution for this?
    Job Ter burg replied 10 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    August 11, 2016 at 4:56 pm
    Can you post a picture of all your AAF export settings?
    Shane
    Little Frog Post
  • Brigitta Bacskai
    August 11, 2016 at 6:26 pm
    this one was the first. Then I tried with converted audio sample rate 48, bit depth 24 and file format to WAV, and also without the AAF protocol but I got the same 60 frame consolidated files.
  • John Pale
    August 12, 2016 at 4:15 am
    Try new a different User Setting or create a new setting.
  • Brigitta Bacskai
    August 12, 2016 at 10:11 am
    Thanks, I forgot to mention but I already tried that, too. Not working.
  • Job Ter burg
    August 15, 2016 at 7:05 am
    Which version specifically? Might be a resurfacing bug.
  • Brigitta Bacskai
    August 15, 2016 at 11:06 am
    The version is 8.5.3. So only downgrade would help?
    b.
  • Job Ter burg
    August 16, 2016 at 10:41 am
    No, I’m not saying that. I have had similar issues in v7.something.
