Activity › Forums › Adobe After Effects › why are my renders “liney”? it looks different than interlacing.
  • why are my renders “liney”? it looks different than interlacing.
    Posted by Jeremy Webb on July 30, 2005 at 7:40 pm
    i rendered a comp that i have been working on using th ephoto jpeg quicktime codec and lower fields first in the field order, and i get these thick horizontal lines sometimes when there’s fast motion. it looks like an interlacing issue, but the lines are probably 5 or 10 times the height of an interlaced line. the lines show up on a computer monitor as well as a ntsc monitor. the footage is basically moving aroun a camera through a bunch of stills. i have some pre-rendered comps nested in the comps. could it be if i prerendered the nested comps with lower fields first in a square pixel comp and then brought them into a comp that was rendered with lower fields first but non-square pixels? (if that makes sense.) or is it some other setting that i have overlooked? i have two stills of footage each a few frames apart, one exhibiting these lines, the other is more normal:
    https://jeremy.banff.org/pics/wed01.jpg
    https://jeremy.banff.org/pics/wed02.jpg
    any help is much appreciated, as this is quite distracting to watch.
    Filip Vandueren replied 21 years, 2 months ago 2 Members · 1 Reply
  • Filip Vandueren
    July 30, 2005 at 9:31 pm
    looks like the video was not interpreted as interlaced, rescaled vertically (by maybe even a tiny percentage), and then de-interlaced.
    Does that look like a possibility, don’t know your workflow ?
