Activity › Forums › Adobe Photoshop › WHY ARE MY PHOTOS BLURRING
Posted by Ariesstarlett on October 18, 2005 at 6:28 pmI cannot figure out why high-res photos are blurring once I place and scale them in a five by five (inch) add.
All three pictures are coming out like crap.
This is urgent too! Even worse.
ThanksRichard Harrington replied 20 years, 11 months ago 4 Members · 4 Replies -
Lriv
October 18, 2005 at 11:13 pmCan you elaborate. What is the resolution of your original pics and what is the res. of the ad? Are you using only Photoshop? Are you scaling the images?
Mark Warmus
October 26, 2005 at 11:27 pmYou can’t take high res images and just jump them down to low res and still mantain a quality image. I stair step it down by droping the res 25% then another 25% and another then sharpen then take it down more and so on and so forth till I have the size I want. Sharpening right before the last time you step it down will get things a little clearer but you have to play with it.
Lriv
October 27, 2005 at 6:49 pmyou actually can take high-res images and drop the res while maintaining image quality…for example:
I took some digital photos at 600 dpi tiffs. I brought them into photoshop and changed the image size to 300 dpi, leaving “Resample Image” unchecked…notice how the dimensions of the image will increase proportionally when doing it this way…now you have a larger photo to work with, thus maintaining quality.
Richard Harrington
October 27, 2005 at 7:00 pmNOT EXACTLY…
You have not resized… just reassigned ppi settings…
If you are using the graphic on screen, for video, or web.. it will not change in appearance… if you print it out… the picture will be bigger, but not as sharp..
Unchecking resample simply means just change the display settings or print size, but don’t change the total pixel values (shich is needed if you are trying to size to a particular size).
Read up on Smart Sharpend and nik Sharperner
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.comedit – produce – direct –
