Activity › Forums › Apple Final Cut Pro Legacy › Why are my HD files being converted to DV/DVCPRO?
  • Why are my HD files being converted to DV/DVCPRO?
    Posted by Aryn Leigh on October 26, 2009 at 3:27 am
    I have FCP on my macbook pro, the version of the program is 6.0.1. Whenever I import at the sequence and import settings “HDV1080-60”, The footage is compressed to DV.
    Seems a simple enough problem to fix but why?
    -AL
    Michael Gissing replied 16 years, 11 months ago 3 Members · 2 Replies
  • Rafael Amador
    October 26, 2009 at 3:49 am
    Hi Aryn,
    That sounds to that your camera is down-converting to DV on play.
    rafael
    http://www.nagavideo.com
  • Michael Gissing
    October 26, 2009 at 3:51 am
    If you select the correct easy setup (in this case HDV 1080 60i) and the camera/ deck is set to output HDV and not downconvert to DV codec then your clips should be HDV.
    Check the Easy Setup and deck settings. There must be a mistake in there.
