Activity › Forums › Adobe Premiere Pro › Why am I getting these artifacts in a screen replacement?
  • Why am I getting these artifacts in a screen replacement?
    Posted by Jeff Davis on January 18, 2021 at 12:21 am
    I’m doing a screen replacement in a static shot by simply superimposing (on a higher layer) a JPEG of the screen I want over the screen in the shot. In the attached screencap, the upper photo shows what I see while positioning the JPEG. The lower photo shows what’s displayed during playback. The problem is those black artifacts across the white lines, kind of moireish. What’s more, I’ll get the artifacts if I scrub through the clip a frame at a time, but they’ll disappear if I stop on a frame for more than a couple of seconds. Any ideas about what’s causing them and how to eliminate them greatly appreciated.
    Jeff Davis replied 5 years, 8 months ago 2 Members · 5 Replies
  • Jerry Wise
    January 18, 2021 at 12:33 am
    In your program monitor are you set to full resolution in playback?
    There is a setting for playback and another for still.
    It’s the wrench icon.
  • Jeff Davis
    January 18, 2021 at 12:54 am
    It’s set to Full.
  • Jerry Wise
    January 18, 2021 at 3:06 am
    Did you find the solution?
    Right now i am editing football footage that is 29.98 upper field.
    When i step forward or backward in source the i see the individual fields, then when i stop 2 seconds later the 2 fields resolve and i get a normal image.
    This sounds sort of like what you are experiencing.
  • Jerry Wise
    January 18, 2021 at 3:13 am
    And i am in show both fields in the program.
    When i switch to display first field all looks good.
  • Jeff Davis
    January 18, 2021 at 3:53 am
    I haven’t solved it, but it doesn’t happen in the exported video, so that’s they key thing. The Display First/Second/Both Fields options are grayed out for me, maybe because this project is 1080p?
