Activity › Forums › Adobe After Effects › why !?
why !?
Posted by Miguel on May 20, 2005 at 3:44 amwhy when i import a comp into a comp the comp came resized?
tnks
Frank Ruggiero replied 21 years, 4 months ago 4 Members · 4 Replies -
Barend Onneweer
May 20, 2005 at 6:08 amAre you sure both comps are exactly the same size?
Usually, a comp that’s dragged into another comp comes in pixel for pixel.
So if the new comp is bigger than the one dragged onto it, you’ll have some empty space around it. Check your comp settings.
Bar3nd
Forum COWmunity leader for:
ADOBE AFTER EFFECTS
MAGIC BULLET SUITE
INDIE FILM & DOCUMENTARY -
Yoondo
May 20, 2005 at 6:48 amPlease you need know the basics before starting to ask questions. Check the manual.
Frank Ruggiero
May 23, 2005 at 6:12 pmcheck to see if your compositions are square or non-square pixels. they must match.
