Activity Forums Apple Final Cut Pro Legacy Whose down-convert is better: Sony deck or Kona?
  • Whose down-convert is better: Sony deck or Kona?
    Posted by Eugene Reynolds on April 6, 2009 at 8:59 pm
    I want to capture HDCam rushes (108025P) from a Sony JH3 as ProRes SD (PAL) to edit with.
    Are there any pros and cons that anyone can come up with to using the Downconverted SDI out of the deck as an SD in to my Kona LHe compared with going HDSDI in and letting the Kona downconvert.
    Whose downconvert is better if any? Or are there any other issues I have not thought of?
    Thanks in advance
    Eugene Lehnert replied 17 years, 3 months ago 2 Members · 1 Reply
  • Eugene Lehnert
    April 6, 2009 at 9:44 pm
    I haven’t used the deck you refer to but HDCAMSR decks have superior downconversion capabilities than the Kona does. “Mode 3” in the HDCAMSR seems to be equivalent to the Anti-Alias + Enhancer of 1 that I like to use in the Snell & Willcox UKON. The Kona seems to have a softer downconversion that does not have any options that you can change.
