Activity › Forums › Apple Final Cut Pro Legacy › who’s using fcp 4.5, qt7 and tiger??
Posted by Derek Woods on May 4, 2005 at 11:13 pmwhats the scoop? should I take the plunge on a g4 dual 1 gig??
Dave Jenkins replied 21 years, 4 months ago 5 Members · 4 Replies -
Videomansf
May 5, 2005 at 12:17 ami am on 10.4 on a dual 2.7 g5, and all is good, but i would hold off till qt 7.1, and fcp 5 come out. compressor is funky under 10.4 and dvdsp 2 is giving me problems.
David Bogie
May 5, 2005 at 3:58 pmThere is no compelling reason to upgrade your OS. You gain nothing tangible in FCP4.5.
But if you feel you MUST have Dashboard, Spotlight, improved winderz networking and the new iChat, be sure to do your homework, prepare your drive and follow the instructions.
Over on apple.com, we’re getting really sick of the “I’m sorry I went to Tiger” posts which outnumber the successful upgrade posts.
bogiesan
Jan Bliddal
May 6, 2005 at 8:44 amyou could buy or use a existing firewire harddisk. Carbon Copy Clone your startup disk to the Firewire harddisk. Boot up from the firewire harddisk. Make an Arcive and installe og Tiger, and try it out. If it breaks your setup Return to your startup disk and wait untill the problems has been fixed. You Might want to upgrade the firewiredisk on a regular basic to check if the problems has been fixed. This approach is a heck of a lot cheaper than downtime do to a incompatible OS upgrade;-)
Dave Jenkins
May 6, 2005 at 4:20 pmWe tried 10.4 & FCP 4.5 and the round trip from FCP to Motion and back
doesn’t keep any of the effects applied in motion when you return to FCP.
We did a clean install and had VERY little installed.
We are back on 10.3.8 thanks to Carbon Copy Cloner.Dajen Productions
Santa Barbara, CA
G5 Dual 2 Gig – AJA IO
Huge 1.2 Raid
FCP 4.5-OS X 10.3.5-QT 6.5
