Activity › Forums › Apple Final Cut Pro Legacy › Who’s Played with ProRes So Far?
  • Who’s Played with ProRes So Far?
    Posted by Sean Oneil on May 22, 2007 at 12:50 am
    I’d really like to know more about it. Is the quality as good as they say it is?
    Also, can you copy the ProRes QT component to another non-FCP6 Mac? I’ll take that question one step further. If you can do that, is it possible to capture ProRes with FCP5? I know you won’t get any RT effects, but is capture possible?
    I have a machine that nobody actually edits on. It’s just an ingest station. I’d rather not pay for an additional FCS2 upgrade if I don’t have to.
    Sean
    Sean Oneil replied 19 years, 4 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    May 22, 2007 at 1:30 am
    You’ll have to pay for the upgrade… you could try what you suggest but I doubt it will work right…
    I’ve played with it a bunch, and it’s fab…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jerry Hofmann
    May 22, 2007 at 1:31 am
    It might actually be against the license terms to do this though…i.e. move the codec over…
    dunno…
    Jerry
  • Sean Oneil
    May 22, 2007 at 4:21 pm
    I hope it isn’t, and I hope they don’t have a problem with it. IMO, this codec is very crippled if it can only be used on computers with FCP6.
    Given the fact that you can’t actually edit ProRes on a non-FCP6 machine with RT Effects, I think that is more than enough to motivate people to upgrade. That alone makes ProRes a “special feature” of FCP6. I should still be allowed to create or at least read that format on any Quicktime machine.
    DVCproHD was a different story. That codec involved a license agreement with Panasonic. Not the case with ProRes.
    It should be noted that Avid does not provide this kind of restriction:
    https://www.avid.com/forms/DNxHDinfo.asp
