Activity Forums Apple Final Cut Pro Legacy Whole sequence needs rendering for some reason. Why?
  • Whole sequence needs rendering for some reason. Why?
    Posted by George Feucht on September 1, 2009 at 5:00 pm
    I need a little help.
    I’m in the process of finishing the color timing of a feature. I did all of the grading in Apple Color in 20 minute chunks (because of Color’s limitations.) After doing the “send to FCP” option, each 20 minute segment turned out fine in FCP. However, the sequence that I am using to re-assemble the 20 minute pieces needs has red across the entire render bar. (The 20 minute chunks need no rendering – they play fine)
    The sequence is the same format and frame rate as the smaller chunks (1080p 1080×1920 10 bit uncompressed) so it’s not like I’m dropping it into a prores sequence or a different resolution. What is going on? Am I missing something?
    Thank you so much!
    -George
    George Feucht replied 17 years ago 2 Members · 2 Replies
  • Aaron Neitz
    September 1, 2009 at 5:15 pm
    Triple check your sequence settings. Are you mixing 24p and 2398psf?
  • George Feucht
    September 1, 2009 at 5:18 pm
    Sequence and clips are both 23.98.
