Activity Forums Adobe Premiere Pro Who know about optimisation PP?
  • Who know about optimisation PP?
    Posted by Jason Pray on April 19, 2021 at 4:32 pm
    Good morning everyone!
    I have some issues with PP, the videos in the timeline with effects getting freeze. Absolutly every effects. I tried everything from the Internet. But it can’t help to me.
    My MAC:
    iMac (Retina 5K, 27-inch, 2017)
    4.2 GHz Quad-Core Intel Core i7
    64 GB 2400 MHz DDR4
    Radeon Pro 580 8 GB
    Please, help me, someone else!
    Regard, Jason.
    Oliver Peters replied 5 years, 5 months ago 3 Members · 6 Replies
  • Oliver Peters
    April 20, 2021 at 3:43 pm
    We need more details. What type of media (format, frame size, frame rate, codec, etc)? What are your sequence settings? What type of effects are you applying? What other gear is connected to your computer? What types of drives are being used for the media?
  • Todd Perchert
    April 20, 2021 at 5:07 pm
    To add what Oliver said, also would be helpful to know how much hard drive space is left on your media drive AND your cache drive.
  • Jason Pray
    April 20, 2021 at 6:05 pm
    Ok.
    Video format: MP4
    Frame size: 1080 x 1350
    frame rate: 25.00 fps
    Sequence settings:
    Editing mode: Custom
    Timebase: 25.00 frames/second
    Pixel aspect ratio: Square Pixels(1.0)
    Field: No Field (Progressive scan)
    Video Previews:
    Preview file format: I-Frame only MPEG
    Effects: Handy Seamless Transitions
    Nothing connected with my Mac
    I have SSD disk on my iMac
    MacOS operating system.
  • Oliver Peters
    April 20, 2021 at 6:13 pm
    What camera is that media from? That’s a weird frame size. Any idea what the nature of the codec is? MP4 is merely a file wrapper. I presume it’s H.264, but it could be something like H.264 10-bit 4:2:2 (used by Panasonic EVA1 cams), which will choke Premiere.
    What are “Handy Seamless Transitions”? I presume some type of third party plug-in.
    Is the media playing from your internal SSD? So, cache files, media, and project are all on your internal drive, right? How fast is the internal SSD? And it is an SSD, not a Fusion drive, correct?
  • Jason Pray
    April 20, 2021 at 6:45 pm
    So, my camera SONY a6400 4K.
    And which is the codec I must use to fast rendering in the timeline?
    Handy Seamless Transitions – this is the only transition presets.
    How can I know that premiere pro is playing from my SSD?
    Yes, all my projects staying on my disks.
    The speed:
    WRITE: 1728.1 MB/s
    READ: 2269.8 MB/s
    I don’t have a Fusion drive, i only have 500 GB SSD drive.
  • Oliver Peters
    April 20, 2021 at 7:42 pm
    Thanks for the details. I would say it’s the codec that your camera generates. I doubt that you will ever get good playback with this codec working natively in Premiere.
    If you are finishing out of Premiere, then I would suggest first transcoding the camera media to ProRes (using Media Encoder). Work with that as your “original,” instead of the MP4 files from the camera. Do a small project this way and see if working with transcoded ProRes files improves your performance.
    I still don’t understand the 1080×1350 size. That makes no sense. Are you sure that’s correct? Typically if you are editing video for broadcast, YouTube, etc. it would be 1920×1080 (HD) or 3840×2160 (UHD 4K) or maybe 4096×2160 (DCI 4K).
    How much empty space is on your SSD? 500GB is relatively small.
