Activity Forums DaVinci Resolve Whites clipping to harsh blue color
  • Mike Most
    February 28, 2019 at 5:43 pm
    If you aren’t already using Log3G10/Red Wide Gamut RGB (aka, IPP2) as your debayer settings, try switching to that. The chroma clipping issue is something we’ve encountered a number of times (particularly on the Helium cameras) when using the previous debayers, such as Dragoncolor. RWG was designed to eliminate that and generally does.
  • Jeremy Hansen
    February 28, 2019 at 5:45 pm
    Thank you for your answer! I am away for a bit but I will try it and report back.
  • Joseph Owens
    March 3, 2019 at 8:36 pm
    [Jeremy Hansen] ” use the color match (an X-rite color checker passport”
    I’d be curious to see your X-Rite before-and-after. It sort of looks like the highlights in the background are correct, and the *clip* foreground has been pumped up over the top, forcing a cyan overshoot.
    jPo, CSI
    \”I always pass on free advice — its never of any use to me\” Oscar Wilde.
Page 2 of 2
