Activity › Forums › Adobe Premiere Pro › White vertival line at end of sequence?
  • White vertival line at end of sequence?
    Posted by Chris Babiana on November 1, 2013 at 7:56 pm
    Everything was working fine yesterday, but today a white vertical line suddenly appeared at the end of my sequence.I tried extending the clip, replaced it with another and the white line always appears at the end of the sequence.
    I updated Premiere Pro CC yesterday
    Does anyone know whats causing this?
    Peter Garaway replied 12 years, 10 months ago 7 Members · 7 Replies
  • 7 Replies
  • Kevin Monahan
    November 1, 2013 at 9:20 pm
    Hi Chris,
    [Chris Babiana] “a white vertical line suddenly appeared at the end of my sequence.”
    That’s an overlay to show you that you are at the end of the sequence. Hope that helps.
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Bret Williams
    November 2, 2013 at 12:00 am
    The line or the answer? 🙂
  • Chris Babiana
    November 2, 2013 at 12:03 am
    Kevin, that’s what it is…marks the end. It wasn’t there before the update and it made me a bit nervous thinking there was another “bug”.
    Thanks for the clarification.
    Chris.
  • Nigel Barker
    November 6, 2013 at 7:19 pm
    It would have been nice if this had been documented then I wouldn’t have spent an hour or two chasing a problem that didn’t actually exist. The update just referred to ‘Bug Fixes’ unless of course this is an unintentional feature aka a bug that got introduced.
  • Dustin Winter
    November 7, 2013 at 2:30 pm
    Is it possible to turn this off??
  • Adrien Boutin
    November 19, 2013 at 5:21 pm
    And how to remove this line????
  • Peter Garaway
    November 19, 2013 at 7:30 pm
    There is no way to hide of turn this off.
    If your not happy with the current implementation feel free to write here:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Peter Garaway
    Adobe
    Premiere Pro
