Activity › Forums › Adobe Premiere Pro › White Space and Import to Encore!
  • White Space and Import to Encore!
    Posted by Carlos Rocha on January 14, 2012 at 1:09 pm
    Happy 2012!
    I have two doubts for a beginner in Encore:
    1) In the video, I had to cut a piece of 3 seconds duration without hacking the audio track. It was an empty space between cuts. How do I fill out the empty space, for example, with an effect?
    2) Well, I rode a string of movies with transitions, reservation of chapters and scenes and everything in Premier CS4 and would like to import this project in Encore CS4 Premiere CS5 do not need to render (or not get it) video in Premiere (and lose the markings of the chapters).
    How do I do that?
    Happy 2012!
    Carlos Rocha
    Carlos Rocha replied 14 years, 8 months ago 1 Member · 1 Reply
  • Carlos Rocha
    January 14, 2012 at 7:59 pm
    Yeah.
    I have not found a way to export to Encore from Premiere.
    Another thing is: With a video broken in two and a gap of 4 seconds between them, as I can, in Premiere, put an end (or transition) between them that lasts 4 seconds?
    The idea here is to remove an imperfection in the 4-second recording. However, I can not cut the audio. So the idea of ​​putting effect between the cut parts of the video.
