Activity › Forums › Apple Final Cut Pro Legacy › White screens after upgrade to Studio 3
  • White screens after upgrade to Studio 3
    Posted by Tom Matthies on April 13, 2010 at 1:43 am
    Yes, the dreaded white screens are back. I did an upgrade from Studio 2 to Studio 3 today. Yes, I know I should have done a clean install rather than an upgrade, but this was an emergency.
    I now have white viewer & canvas screen. I did a search on this and found numerous others with the same problem. What I didn’t find was the definitive fix to the problem. I’ve done the usual trashing of preferences. The windows are NOT set to alpha but are on RGB. If they are set to alpha/RGB the video can now be seen under the transparent red alpha screen. The video plays out normally through the Kona card and my AJA IO. Everything seems to work normally except for the white screens. I’ve also tried to reset the screen resolution and size preferences. Nothing has worked. I’ve also created a new user. Still NG.
    And, of course, I have five spots waiting to be edited with a tight deadline.
    Not a good day today…
    Anyone know the answer to this one?
    Tom
    Life moves pretty fast. If you don’t stop and look around once in a while, you could miss it.–Ferris Bueller
    Michael Gissing replied 16 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Tom Matthies
    April 13, 2010 at 1:46 am
    BTW:
    Mac Pro 2×2.8 quad core Xenon
    10Gb RAM
    OS 10.5.8
    Studio 7.0.1
    Quicktime 7.6.6
    Also note that video will play fine in Quicktime player
  • Neal Broffman
    April 13, 2010 at 2:56 am
    One possible solution:
    Do you have Magic Bullet Colorista? If so, update it and see if the problem goes away. This happened to me, and others, and it fixed the problem (the motion templates in FCP appeared as white screens).
    Neal Broffman
    One Production Place, Atlanta, GA
    “Voices of Freedom”, Special Jury winner for Fall 2008 CINE Awards produced for the High Museum of Art in Atlanta as part of a major exhibition of vintage Civil Rights Movement photographs, “Road To Freedom”. Currently on display at The Bronx Museum (through August) after having been on exhibition at the Field Musuem in Chicago, The Skirball Cultural Center in LA and The Smithsonian in DC.
  • Tom Matthies
    April 13, 2010 at 4:00 pm
    Nope.
    No Colorista installed. I’ve removed all of the Plug-ins for the time being and restarted. Same problem. Removed Perian-same problem. New user-same problem. Screen resolution & color depth-same problem. Trashed prefs-same problem. Repaired permissions-same problem.
    Running out of ideas…
    I did back up the system drive before upgrading. Looks like I might have to boot from the backup to get through the next round of spots coming in.
    I put off upgrading just for the problems early on in this version.
    This seems to be a common problem with upgrades. Surely someone has found the solution by now?
    Sheesh…
    Tom
  • Tom Matthies
    April 13, 2010 at 6:41 pm
    I installed my cloned system drive and booted from it and everything came up fine. Glad I made a backup before doing the upgrade. I’ll have to deal with the upgraded software later.
    Apple upgrades: One step forward and two steps back…
    Shouldn’t be this way.
    Tom
  • Mike Kahn
    April 13, 2010 at 7:09 pm
    Try a new user. Under system prefs, create a new user and open FCP. Guarantee it will fix the problem.
    I don’t know what the problem is exactly, but something gets corrupted in the user prefs and creating a new user and using that will fix it.
  • Tom Matthies
    April 13, 2010 at 11:52 pm
    I tried creating a new user yesterday and it didn’t solve the white screens of agony problem. Still running off of my cloned backup drive today.
    AAggggrrrrhhhhh!
    Upgrades!!!
    Tom
  • Michael Gissing
    April 14, 2010 at 2:04 am
    Firstly kudos for making a clone. Secondly thanks for providing another reason why it is faster to do a full clean install instead of an upgrade over FCS2. Less haste, more speed as my grandmother used to say.
    I guess when you have time to do the proper FCS3 install all will be fine.
