Activity Forums Apple Final Cut Pro Legacy White screen until I hit play
  • White screen until I hit play
    Posted by Doug Normington on July 27, 2013 at 5:17 pm
    I am using Final Cut Pro 7.0.3
    I just logged and transferred a bunch of footage. When I put a clip in the source window so that I can set my ins and outs. Here is what happens. Unless I am in PLAY. I can’t see the footage in the window when it is stopped I cannot see the footage when I scroll.
    When I scroll I can hear the audio. But visually… all I get is a white screen
    If I drag a clip into the timeline.. it works normally.
    Thank you in advance
    Doug Normington
    NORMCO Multi-Media, Inc.
    (608) 824-0999 Office
    (608) 345-7579 Cel
    Jim Scott replied 13 years, 1 month ago 2 Members · 1 Reply
  • Jim Scott
    July 28, 2013 at 2:35 pm
    In the View pop-up menu (the third one to the right – looks like a square) at the top of the window, make sure it is set to RGB. I’m guessing that you accidentally switched it to Alpha.
