Activity Forums Adobe After Effects white screen keying
  • white screen keying
    Posted by Blake Harrington on March 6, 2010 at 4:54 pm
    I have footage shot on white screen instead of green and I need to key out the background. If I use a highly feathered color key and and keep the background as close to white I can get the shots looking okay but not great. The biggest problem areas are the shadows under the people. I don’t have time to hand mask out everyting and was wondering if anyone had any ideas. Also is there a better plug in for this kind of keying than the ones that are included with after effects?
    Blake
    Blake Harrington replied 16 years, 6 months ago 5 Members · 6 Replies
  • Todd Kopriva
    March 6, 2010 at 8:14 pm
    Are you using the Luma Key effect?
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Blake Harrington
    March 6, 2010 at 8:26 pm
    I was using the color key
  • Michael Szalapski
    March 6, 2010 at 9:30 pm
    The difficulty with keying white is that anything with highlights is going to be white. Are there glasses, jewelry, metal, skin tones, hair, or anything remotely shiny? If so, you will get highlights that will get very close to white.
    You can try the Luma key effect that Todd suggested and it will probably work better than the color key effect.
    You may need to break your shot up into several different pieces, key each piece with separate options in your keyer and composite them all together.
    Is it possible for you to post a still image for us to take a look at?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Joe Coleman
    March 8, 2010 at 12:30 am
    I like the linear color key for keying out black or white. “Key Correct” plug-ins can also be really helpful for difficult keys if you want to play around with those. If you lose eyes, teeth, etc, duplicate the footage, take the key off the bottom layer and animate rough mask under the face to preserve things that get keyed out.
  • Scott Roberts
    March 8, 2010 at 9:30 am
    I’d do the same as Joe Coleman suggests.
    https://www.youtube.com/graphicsdump
    https://www.myr3d.com
  • Blake Harrington
    March 9, 2010 at 4:11 am
    Thanks for all the advice, think I used all of it. I ended up using Color Key a lot, then Luma Key, and a little Primatte. Sometimes by themselves and sometimes together. A couple shots keyed out really well but most had to have a white halo around them. Using masks to get back the inner parts helped too. It’s far from perfect but there is no time to roto every frame.
