Activity › Forums › Apple Final Cut Pro Legacy › white screen in canvas/ no image when timeline paused
  • white screen in canvas/ no image when timeline paused
    Posted by Ryanschlagbaum on December 6, 2005 at 3:18 am
    This is probably a very simple fix, but I can’t find it anywhere. Normally the canvas shows a still frame where you are stopped in the timeline. I bumped some shortcut (I guess) on my keyboard and now whenever I stop playback in the timeline, the canvas becomes a plain white screen. Does anybody know how to get my canvas to show the still frame again?
    Luke Jeffery replied 12 years, 7 months ago 7 Members · 9 Replies
  • 9 Replies
  • Don Greening
    December 6, 2005 at 4:51 am
    Go to the top ov your canvas window where you’ll find a small pull down menu. Choose the RGB setting instead of the gamma setting.
    – Don
  • Don Greening
    December 6, 2005 at 4:59 am
    Sorry…….I meant Alpha setting, not Gamma setting. There’s 3 pulldown menus at the top of the window. Go to the one furthest to the right.
    – Don
  • Samir Mello
    October 11, 2008 at 4:21 pm
    Thanks Don !
  • Andy Wood
    October 10, 2010 at 1:02 pm
    I’ve had exactly the same problem in FCP 7 and checked my settings but all correct. (ie it IS set to Alpha). I am also getting a “General Error’ message when i try to export the timeline but dont know if these problems are connected. Anyone with any ideas or help please?
  • Lars Fuchs
    October 10, 2010 at 9:52 pm
    Just had the same “white frame in pause” problem, and found that the dropdown was set to ALPHA instead of RGB.
    [Andy Wood] “my settings but all correct. (ie it IS set to Alpha)”
    When I set it to RGB everything went back to normal. I’m using FCP 7 too. Don’t really know how this got changed, but happy it was an easy fix. Glad I thought to search the forum before undertaking any more radical repair measures!
  • Lars Fuchs
    October 10, 2010 at 9:53 pm
  • Andy Wood
    October 10, 2010 at 10:18 pm
    Yep, you’re right Thanks. It should be set to RGB (not Alpha). Dont know how it managed to change itself either (;)
  • John Buck
    December 2, 2013 at 7:05 am
    almost Eight years after you posted a reply – this tip saved me today.
    From Melbourne
    JB
  • Luke Jeffery
    February 17, 2014 at 9:40 am
    Thanks mate. This tip just helped me out.
