Activity › Forums › Maxon Cinema 4D › White outline arownd shadow catcher
  • Brian Jones
    March 9, 2018 at 7:06 pm
    what version of C4D?
    What Shadow Catcher? the built in shader or the old plug-in?
    Compositing in C4D or AE (or something like it)?
    Can you post the scene file ?
  • Zorro Gamarnik
    March 9, 2018 at 9:58 pm
    Hello Brian, Thanks for the response.
    The version is R18.
    As shadow catcher I am using is a plane object with colour only texture apply to it (white).
    For compositing in AE I am using L Matte for plane object and Shadow image layer above.
    I am using straight alpha in c4d and AE. I have tried physical and standard renders.
    file:
    12235_project.zip
  • Zorro Gamarnik
    March 9, 2018 at 10:09 pm
    Brian, I forgot to mention that I have changed colour of the shadow catcher material colour from white to black.
    Well…. now it’s black outline. Looks better for this scene but it’s not a solution. 🙁
  • Brian Jones
    March 10, 2018 at 12:55 am
    the Shadow Catcher shader is an Advanced Render thing (well, you can use it with Physical but the alpha channel colours seem backward) it’s in the help here – Reference/Cinema 4D/Cinema 4D Visualize, Broadcast, Studio/Advanced Render/Shadow Catcher
    If you turn on Include Lighting in the Shadow Catcher tab it should look better with your scene with multiple lights.
  • Zorro Gamarnik
    March 11, 2018 at 12:11 am
    Thanks Brian
