Activity › Forums › Apple Final Cut Pro Legacy › White lines and double figures…
  • White lines and double figures…
    Posted by Jim Makichuk on May 13, 2012 at 10:29 pm
    I captured 87 minutes of my feature off a DVD into FCP7, intending to make a little trailer. The DVD came from digi-beta and was shot on 35mm way back in 1980.
    About 30% of the clips have odd white lines that outline a figure (head, face, body, etc.) I made a QT and noticed that one clip showed up as green (no image at all). And when I slow-mo it in timeline the first frame has white horizontal lines top to bottom.
    They seem to appear around highlights, so I figure they are zebra fx but are white, not green. Also had a few freezes as well. Piece is less that 4 minutes. And wonder why that one clip shows only as a green screen in QT file.
    Jim Makichuk replied 14 years, 4 months ago 2 Members · 4 Replies
  • Jerry Hofmann
    May 14, 2012 at 2:59 pm
    What codec did you capture the betacam with? DV or?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Jim Makichuk
    May 14, 2012 at 9:54 pm
    Was no betacam, it was from a dvd master that was made from a digi-beta. It was a pretty big clip, 87 minutes and total 283 GB! That could be the problem?
  • Jerry Hofmann
    May 14, 2012 at 11:24 pm
    You captured it to what codec? ProRes? SD or or HD or DV or? Or you transcoded the DVD files?
    Jerry
    Current DVD:
  • Jim Makichuk
    May 15, 2012 at 12:01 am
    captured in ProRes, put the DVD thru streamclip to produce the QT file. I’m gone for 2 wks and once I get back I’m going to pick up with DVDSP and start at the beginning. Meantime I got a friend at an agency to make a DVD master from my QT file for my director friend.
    I know it’s one of those things that once I understand it it will probably be simple. Took me a long time to figure out pan/scan.
    thanks, all of you for trying to figure out what I did. Steenbecks were easier, just forward and reverse and an occasional light bulb replacement.
