Activity Forums Avid Media Composer White in Timeline
  • White in Timeline
    Posted by Chip Hess on August 10, 2014 at 2:56 pm
    So I create a 100% white frame in Marquee, to drop into the timeline and use as a background.
    It displays as slightly grey when cut into the timeline. I have to use Color Correction to raise
    the brightness.
    I have experienced this on two systems, at work and at home.
    Both running MC 6.
    In SD and 1080 HD.
    What gives?
    Glenn Sakatch replied 12 years, 1 month ago 3 Members · 3 Replies
  • Michael Phillips
    August 10, 2014 at 3:09 pm
    Title Tool, and most likely Marquee legalize levels into video specs when saving – so what would be full white 255 RGB is now 235 RGB.
    Media Composer is a Rec/601/709 system. You can cheat it and work full wing with imports, and now LUTs to go full scale, but there are still operations like titles and some VFX renders that will make legal video.
    In your case, create the white frame outside of Media Composer and import with 601/709 levels so that Media Composer leaves it alone.
    Michael
  • Chip Hess
    August 10, 2014 at 3:18 pm
    That’s it!
    Thanks very much.
  • Glenn Sakatch
    August 10, 2014 at 3:46 pm
    I usually have a White and a Black .tif file living in a common area for me to import into any sequence I need them for.
    Glenn
