Activity Forums Apple Final Cut Pro Legacy White Gamma Shift Around Edit Points
  • White Gamma Shift Around Edit Points
    Posted by Scott Mcintyre on June 23, 2010 at 1:16 pm
    After exporting a project from FCP that was Canon5d H264’s transcoded to pro res hq, I have found gamma shifts in the the clips right before cuts, doesn’t happen every time. But enough that the client will notice. While playing in FCP there is no issue, soon as an export to Pro Res Hq happens then there is the gamma shift? Anyone seen this before?
    Scott Mcintyre replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
