Activity Forums Maxon Cinema 4D White frames in material
  • White frames in material
    Posted by Amish Ed on December 8, 2006 at 5:33 pm
    Hi all, I’m having what seems to be a wierd issue. I have 8 objects in a scene, each has a flat area which acts as a video screen. The videos look and play smoothly, but I’m getting white frames where each video loops. The videos vary in length from 3-10 sec. and all loop throughout the 1:08 final render. They all have the white frames, but the # of frames vary from 2-8 white frames each. Any ideas what could be doing this?
    Amish Ed
    “Shoot ’em all and let the Editor sort ’em out!”
    Dual 2Ghz G5, 4GB, running 10.3.6 w/QT 6.5.2, Black Majic DeckLink, AE Pro 6.5 w/BCC and Invig. 3D, PS CS2, AI CS2, FCP HD
    Mylenium replied 19 years, 9 months ago 2 Members · 1 Reply
  • Mylenium
    December 8, 2006 at 8:13 pm
    Have you set the properties of the animated textures properly? Check that. Just for verification use C4D’s “Calculate” function to see if it interprets the lengths of your clips correctly.
    Mylenium
    [Pour Myl
