Activity Forums Adobe Premiere Pro White Flicker h.264 DSLR1080p Timeline
  • White Flicker h.264 DSLR1080p Timeline
    Posted by Benjamin Thompson on February 16, 2013 at 5:25 am
    Hey Everyone.
    I’m putting together a project (shot on canon 60D at 1080p 29.97fps) There is an intermittent white flicker that appears on most clips at random. I’m using the DSLR 1080p present in Premiere 5.5 and dont’ have the storage space to transcode.
    The flicker also happens in the source monitor.
    All videos play fine in the finder, but in the timeline there is a flicker.
    Any thoughts or ideas? I hope I’m missing something simple.
    Naveen Alle replied 11 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Ivan Myles
    February 16, 2013 at 4:40 pm
    • What codec (H.264/MP4?) and compression settings were used to record the video?
    • Did you try to render a preview of the timeline?
  • Ivan Myles
    February 16, 2013 at 4:42 pm
    Sorry, just saw the H.264 in the title… but would still like to know the compression settings. Thanks.
  • Benjamin Thompson
    February 16, 2013 at 5:47 pm
    Thanks Ivan. The footage came straight from the 60D (h.264 Linear PCM, uncompressed audio 16bit 48kh in quicktime wrapper). About a 45Mbit/s.
    Not sure if that’s what you were looking for. As it turns out it doesn’t export in the render (both 422 HQ and Vimeo HD mp4) as far as I’ve noticed but it’s a bit irritating while editing.
  • Ivan Myles
    February 16, 2013 at 7:05 pm
    I thought there might be an All-I setting on the camera. I just looked through the user guide and did not see any, so please disregard.
    Not sure if we are referring to the same thing. When previewing compressed footage it might be necessary to render the sequence so Premiere doesn’t need to decode and apply effects on the fly. From the main menu select Sequence > Render Entire Work Area.
    To troubleshoot the issue we need to determine whether the flickering is a problem with the source file, reading the file, or previewing:
  • Are there any noticeable issues when looking through the video frame by frame?
  • Are you reading the file from a memory card or harddrive?
  • Did you render a preview of the sequence as described above?
  • If you export a short clip, do you see any issues with the output file?
  • Benjamin Thompson
    February 16, 2013 at 7:34 pm
    Sorry. I should have been more clear.
    I think we were confusing the word render (I work mainly in AE) I’d pressed “enter” which apparently wasn’t rendering all the clips, just the red line areas (artwork). The video clips remained with yellow lines. After I completely rendered the clips in the time line there was no flickering on playback within premiere.
    No noticeable issues frame by frame.
    Reading files from external drive (Firewire 800).
    Previewed as described above and playback was flawless.
    I exported 2 clips (422 & mp4) Both had no flickering and no visible issues.
    Looks like the issue is when the video clips have yellow lines above them, some sort of realtime preview glitch. I don’t think it’s happened before with codecs other than h.264 in my case. It happens sporadically but now that I know when I completely render the timeline I can they disappear I can edit with confidence.
    Thanks for your speedy replies and assistance.
  • Ivan Myles
    February 16, 2013 at 8:55 pm
    Happy to help.
    There are two types of renders for previewing: Render Effects in Work Area, and Render Entire Work Area. Enter is a shortcut to Render Effects. Adobe Help provides a brief description.
  • Naveen Alle
    December 10, 2014 at 2:40 pm
    Hey Ivan,
    I have the same problem. There is white color flicker in the program monitor but the source monitor is flicker free. The rendered output also has the flicker.
    Please help.
  • We use anonymous cookies to give you the best experience we can.
