Activity Forums Adobe After Effects white flashes in vis – urgent help needed pls
  • white flashes in vis – urgent help needed pls
    Posted by Paul Hasler on August 3, 2005 at 5:46 am
    Hi
    I’m working on a project in AE with 25p vis. I’m not sure if I’m doing it right but when i try and render out my project there is white flashing through out.
    I have turned separate fields to OFF and the same when I render out. I have also tried every combination of this with upper field first just in case and still there is white flashing which is visible as i scroll along the timeline as well.
    I really don’t know what is going on or how to fix it. Any help would be greatly appreciated.
    Paul
    Paul Hasler replied 21 years, 1 month ago 2,898 Members · 1 Reply
  • Paul Hasler
    August 5, 2005 at 12:28 am
    I have now realised that it is not just flashing for progressive vis but now all vis. Could it be a plugin or codec???
