Activity Forums Adobe Premiere Pro White Flash Frames in Export
  • White Flash Frames in Export
    Posted by Joe Sinopoli on April 12, 2014 at 9:10 pm
    I have a fairly complicated sequence — nests within nests, adjustment layers with noise, and it’s mainly still images (at one point, 32 different layers of stills at one time) — but every export has white flash frames consistently through it.
    I have tried troubleshooting in every conceivable way — getting RID of the nests, relinking the still PNGs to JPGs, no noise layers, etc. — but it still always has the white flash frames. And the frames are at DIFFERENT times in the export, ie: on one export it’ll be in a specific portion of the cut, but then if I try exporting again, it’ll appear in a different part of the video. Furthermore, I’ve tried exporting in most imaginable codecs. Even the targa sequence had the frames of white.
    I had to revert to screen-capping the video FROM Premiere to Quicktime just to send the client a version. Any solutions?
    Joe Sinopoli replied 12 years, 5 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    April 13, 2014 at 10:54 pm
    export as an image sequence – if you say that the white frames are fully random, then you can see the white frames in Finder and re-export those portions until you get a clean render you can convert to a video file using Premiere or AME.
    Sometimes getting the work done trumps figuring out whats happening when you have client deadlines.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Joe Sinopoli
    April 13, 2014 at 11:07 pm
    Well I did try exporting as a Targa and TIF sequences, but the frames still appeared in the image sequences (often every other frame for seconds at a time). While they are random at times, the more complicated parts of the sequence ALWAYS have them, so a try-until-it-works method won’t work.
