Activity › Forums › Maxon Cinema 4D › White edges when adding individual elements to a matte painting in Cinema 4D
  • White edges when adding individual elements to a matte painting in Cinema 4D
    Posted by Simon Matthews on February 25, 2013 at 12:25 pm
    Hi, I have a landscape scene that I produced in Photoshop and now I want to project it onto some geometry. I have several trees that are on separate layers and want to project them onto planes. I create a material and load the tree image into the colour channel, then load the same tree image into the alpha channel, then drag it onto the plane, but am left with an ugly white edge around the tree. This white edge doesn’t show up in the Photoshop image, only in C4D. Am I doing something wrong? Is there any way to eliminate the white edges?
    Simon.
    Simon Matthews replied 13 years, 7 months ago 2 Members · 5 Replies
  • Simon Matthews
    February 25, 2013 at 2:06 pm
    Update:
    When loading the image into the colour and alpha channels, originally I clicked on ‘no’ when asked to create a copy of the image in the search path. I just tried clicking ‘yes’ instead and the results are much better, though still not quite perfect.
    Simon.
  • Brian Jones
    February 25, 2013 at 4:38 pm
    if the trees are on a null background or on a white background the antialiasing bleeds into the white which gives you the white line. Either choke in the alpha a bit or put the tree on a black background (or brown etc) and then export so the antialiasing bleeds into a color that is much closer to the tree color.
  • Simon Matthews
    February 25, 2013 at 5:56 pm
    Thank you very much. My trees are on a transparent background. Is there a way I can choke in the alpha within C4D or do I have to do it in Photoshop?
  • Brian Jones
    February 25, 2013 at 6:07 pm
    it has to be photoshop I think. You can add a background there too the only thing that matters is the Alpha channel not transparency – choking is fine too if you don’t loose too much detail.
  • Simon Matthews
    February 25, 2013 at 6:11 pm
    Ok, I’ll have a practice with that and see how it turns out, thanks again 🙂
