Activity › Forums › Canon DSLR Cameras › White dot only seen on Movies – EOS5Dii
Posted by Efe Ersoy on August 2, 2011 at 9:26 amHi all
Recently my EOS5Dii started to add a single tiny white dot on movies. On photos there in none, even I take the smallest jpgs. Obviously it is not a dust.
Any ideas what is causing this?
Regards
Efe Ersoy
Edmond Ranson replied 14 years, 8 months ago 4 Members · 6 Replies -
Pete Burger
August 2, 2011 at 11:55 amCould be a dead pixel. Had that problem a couple of months ago with tmy T2i. Mapping dead pixels out is quite easy:
Switch off the camera, remove the lens, put the body cap on the camera and switch it on.
In the menu go to “sensor cleaning” –> “clean manually”. After a few seconds switch the camera off. Now the pixel should be gone.hth
“Tragedy is a close-up; comedy, a long shot.” – Buster Keaton -
Pete Burger
August 5, 2011 at 8:01 amYou’re welcome!
Efe Ersoy
August 5, 2011 at 11:24 amI thought manual clean means brushing the sensor. It really worked. Thanks a lot!
Pete Burger
August 5, 2011 at 12:14 pmHappy to read it worked!
This feature is indeed the only way to manually clean the sensor, since the mirror snaps back and you have access to it. The “mapping-out-dead-pixels”-feature is a “by-product” 😉
