Activity Forums Apple Final Cut Pro Legacy White circle with black cross inside…
  • Tom Matthies
    October 5, 2007 at 1:17 am
    It means that the frame you are parked on has not rendered itself yet for playback.
    If you have a lot of filters or effects on a frame it will take a second or two to render itself when you park the playhead on that frame. Once the circle goes away, the frame is showing a fully rendered scene.
    Tom
  • Diego Villalba
    October 5, 2007 at 9:43 pm
    Thank you Tom.
    Best wishes.
    Diego
    Die Go
