Activity Forums Adobe Premiere Pro White balance question.
  • White balance question.
    Posted by Brian Macaione on April 4, 2019 at 10:10 pm
    Hello,
    The old three way color wheel in Premiere used to let you use an eye dropper for setting the high, mids and lows separately. Now when I use Lumetri, the only eye dropper I can find is to just set an over all white balance, not the three separate as before. When you select “color wheels and matching” in the panel, it does not have options for eye droppers? I can adjust them manually by hand, but I found this to be inaccurate. Does anyone know if there is a way to get the eye droppers back?
    Brian Macaione replied 7 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
