White Balance in PP
I did a test to see if the correct white balance temp would show on the LCD/viewfinder when using a Picture Profile with a preset color temp.
I set two PPs, one at 5600K, one at 7200K with all the other settings at default, and named the Profiles 5600K and 7200K accordingly.
When the PP was selected, the LCD did show the correct white balance, but the white balance switch must be set to Preset, not to A or B. If A or B is selected, you will see the last reading for those values and not the value selected in the PP.
Because of how I named the PPs, I had 5600K or 7200K appear at the bottom of the screen twice, so I didn’t really need to have the Display PP set to ‘On’.
Hope this helps.
