Activity › Forums › Sony Cameras › White balance and lighting
Posted by Kent Beeson on February 24, 2010 at 12:55 amHi guys
Just wondering about lighting and white balance on this situation – full day light coming in through massive windows, with these lights overhead…what would you do re: white balance and lighting? Using EX1R.
Oscar dario Jimenez escruceria replied 16 years, 6 months ago 7 Members · 13 Replies -
Richard Crowley
February 24, 2010 at 2:38 amI have a similar situation coming up with a massive array of windows letting in lots of 5600K++ sky light. I only have enough color correction/ND film for part of one window.
So I was going to experiment with getting some orange double-knit polyester fabric which is just about the cheapest fabric at the cloth store. The fabric is semi-transparent, so it will block maybe 2-3 stops of absolute level, and the orange color will bring the very high color temp outside down to something more compatible with the tungsten interior lighting.
Derek Reich
February 24, 2010 at 4:33 amIt looks predominantly daylight, so your balance is certainly going to be on that end of the spectrum. Depending on the overheads (they could be tungsten, halogen, or maybe even fluro) you are either going to have to live with some warm hues under the lights with a near daylight balance, (probably what would look best) or risk blue hue near the windows with a warmer balance for the lights. Another option is to replace the lamps in the overhead fixtures with lamps which have a closer to daylight balance or gel the overheads with blue gels. It’s hard to tell from the photo, but those overheads already look like they’re on the ‘cool’ side of color temperature. You may be better off than you know… get a balance directly under those lights if you can, and determine the temperature. Then get one near the windows about the same time of day as your shoot (and hope the clouds will be the same) See how far apart you are and go from there with respect to dealing with the overheads. Good luck! It’s hard to find a ‘perfect’ balance in situations like this, but you’ll likely find one which works…. the fact that you are thinking about this ahead of time is a good sign!
Good luck- -
David C jones
February 24, 2010 at 4:40 amHi Kent,
Unless you have total control of the windows, you’re best bet is to white balance near the windows and let the interior lighting be what they will. I’ve had to do this many times.
Just remember: sunlight and daylight will ALWAYS overpower tungsten lighting or, at best sneak its way in 🙂
Best,
Dave J
Kent Beeson
February 24, 2010 at 4:59 amVery interesting – would’ve never known to do what you just suggested. Appreciate your reply.
K
http://www.effectivevideo.net -
Kent Beeson
February 24, 2010 at 5:02 amI meant the orange cloth business in my reply above – but thanks also David.
One time in the past I white balanced under similar conditions under the tungsten and the flesh tones were very orange, horrible…so I needed other pro advice this time…thanks.
K
Kent Beeson
February 24, 2010 at 5:06 amThat’s a great and simple idea – blue gel the overheads (if I can), very good solution….thanks very much to everyone for helpful thoughts…good forum here.
K
Steve Wargo
February 24, 2010 at 1:27 pmTry a preset white balance of 4600 using the picture profile. from there, adjust 100 at a time till it looks correct. Make sure you look at a monitor in a room that is not flooded with this room’s light, like a room with no windows.
Steve Wargo
Tempe, Arizona
It’s a dry heat!Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1 HD .Ask me how to Market Yourself using Send Out Cards
Ronnie Martin
February 24, 2010 at 2:39 pmUnless you are going to do a lot of camera moves Panning and so on, I would use a white warm card to WB near the subjects position. Now if this is part of a bigger project with many clips from different lighting conditions, it will be a job for the color correction properties of your editing software…..
Good Luck
Ronnie Martin
https://www.dirtracingvideo.comRonnie Martin
Kato Video Productions
http://www.dirtracingvideo.com -
Kent Beeson
February 24, 2010 at 5:11 pmGood advice, thanks…I’ll try that re: PP at 4600 then play with it by 100’s. Also, if I went the route of gelling the lights (regardless of whether they were tungsten or otherwise, would this bring the lights to match the outdoors?
https://www.filmtools.com/litepanels-ringlite-single-filter-full-ctbl-rlc-f-full-ctb.html
K
David C jones
February 24, 2010 at 6:08 pmGelling the lights to match the outdoor light will work, but you need to know the color temp. of the light you’re gelling (you can get that from the camera).
You may not want to gel them to match exactly, though. They should give off at least some of their natural color temp; even our eyes see differences in degrees kalvin.
Keep in mind, the outdoor color temp. will change throughout the day as well.
Dave J
