Activity › Forums › VEGAS Pro › white balance
  • white balance
    Posted by Leslie Wand on June 29, 2005 at 9:02 am
    sorry if it’s already in the archives somewhere – am stuck working online away from home.
    i remember reading somewhere that you could use colour corr. (or secondary), to pick the white level in a shot, and then transfer it to other clips?
    the practical is there’s this bloke here who’s shot a wedding and interiors ok, but blue in shadow. i thought with the above he could do a quick colour correction?
    any walk through, or other suggestion most welcome…
    leslie
    Leslie Wand replied 21 years, 3 months ago 5 Members · 8 Replies
  • 8 Replies
  • Gary Kleiner
    June 29, 2005 at 2:43 pm
    [leslie wand] ” pick the white level in a shot, and then transfer it to other clips?”
    Unfortuneatly, Vegas has no such function. However, once you work out the right color correction on one event you can apply it to other events by copying and pasting event attributes. If the tape is consistant throughout, you can apply color correction to every instance of it by applying it in the Project Media (Media Pool) tab.
    Gary Kleiner
    Vegas Training and Tools.com
  • Chris Young
    June 29, 2005 at 3:19 pm
    Leslie ~
    To the best of my knowledge there is no ‘auto color correction’ copy mode in Vegas like you have in some of the other NLE software. If there is a way to do it in Vegas please someone tell us. It would be a great bit of knowledge to have.
    Two cents worth here.
    Method 1. If the sections of video are different clips park the cursor over a clip where the color is ok then hit the ‘copy snapshot to clipboard’, second icon from right above the preview window. Next select the ‘split screen view’ icon, fourth icon from left above preview window. Next drag the cursor to the clip that needs color correction. If it’s part of the same clip from where the color was okay but now incorrect split the clip where needed add the ‘color corrector’ plugin to the new clip. Now make adjustments to say the ‘low’ color wheel and maybe clear the blue cast from the shadows to match the split screen view.
    Method 2. Sometimes I find a more subtle way if it’s just a colorcast that needs removing is to use the ‘color curves’ plugin. If you want to minimise a blue shadow cast uncheck the ‘show all channels’ box and select ‘blue’ from the drop down in the ‘channels’ dialogue window and then just stretch, swing and move the nodes in the window until you get the correction you want.
    All the time remembering that you can save any of these settings in their respective plugin windows as new ‘user presets’ for later recall. Good luck squire!
    Chris Young
    CYV Productions
    Sydney
  • Chris Young
    June 29, 2005 at 3:22 pm
    Good one Gary! I like it.
    Chris Young
    CYV Productions
    Sydney
  • Leslie Wand
    June 30, 2005 at 5:51 am
    thanks gary and chris.
    i’ve passed the info on, and if i get a chance i’ll stand over his shoulder when he tries……
    i suggested he simply goes sepia – but then again, i’m lazy.
    thanks again,
    leslie
  • Bill Ravens
    June 30, 2005 at 2:29 pm
    May I suggest a third party plugin which works pretty well for white balancing?
    The download is here: https://mikecrash.wz.cz/
  • Leslie Wand
    July 1, 2005 at 11:18 am
    couldn’t get any complete downloads?
    will try again, maybe too much traffic? (for a vegas plugin!?)
    leslie
  • Edward Troxel
    July 1, 2005 at 1:28 pm
    Must be a website problem. It’s only 57k. I’ve downloaded it in the past. Send me an e-mail and I’ll send it to you.
    Edward Troxel
    JETDV Scripts
  • Leslie Wand
    July 1, 2005 at 11:11 pm
    thanks for the offer edward, but chris got in before you by sending it.
    many thanks for the offer though.
    all the best,
    leslie
