Activity › Forums › Panasonic Cameras › White balance
White balance
Posted by Roger Sherman on June 10, 2005 at 1:33 amall of a sudden the preset white balance isn’t working. everything is blue. manually white balancing is fine. is there a way to re-set it?
Janet Turner replied 21 years, 3 months ago 3 Members · 5 Replies -
Noah Kadner
June 10, 2005 at 2:17 amToggle the white balance preset switch- make sure it’s on ATW. I always recommend manual anyway unless you’re in complete run and gun mode.
Noah
Janet Turner
June 10, 2005 at 12:19 pmNoah –
Please forgive my ignorance. I have been reading Barry’s book as well as the owner’s manual and I am still confused about how to do a manual white balance. Would it be possible for you or anyone else to walk me through the steps. I understand the preset but both of my A and B switches always show Bch unless I toggle the A switch on the side of the camera to the point where an A shows up on the LCD screen and Bch goes away. Do I get to manual mode for white balancing through a menu item? Once I find the manual balance, do I then focus the camera on a whiteboard and shoot about 5 seconds of video to establish the white color or do I do it some other way? My older camera did not have manual white balance capability so this is all new to me.
Sorry for not getting this!
Grasshopper
Roger Sherman
June 10, 2005 at 12:32 pmthe A & B allow you to manually set two different white balances. for example, you may abe shootig a scene where you go inside and outside. switch to A or B, hold a white card in front of the camera in a place where the light is most typical of the scene you’ll be shooting, hold the AWB button on the front of the camera until it says OK and you’re set.
Janet Turner
June 10, 2005 at 4:52 pmRoger –
Thank you for clearning up how to white balance. Naturally, I ran over to the camera and did what you said. By going to two different lighting situations, I could see clearly the difference in white balancing. Thank you again for responding. Up next is trying to figure out what I am suppose to do with a focus card but I think DV Rack walks me through it.
Grasshopper
Janet Turner
June 11, 2005 at 3:58 pmJust finished Barry’s book and got the answer to a lot of my questions. Great resource. Thank you Barry for all your hard work.
Grasshopper
