Activity Forums DaVinci Resolve White balance
  • White balance
    Posted by Jean Tertrain on August 11, 2025 at 2:10 pm
    Hello,
    Is there a way I can make these two shots white balance match, in a faster way than moving the Global button below ? I’m struggling.
    Thank you,
    Jean
    Mads Nybo jørgensen
    replied 1 year ago
    2 Members · 1 Reply
    August 11, 2025 at 2:24 pm
    Hey Jean,
    Have you tried that from Davinci’s “sales” page?
    Auto Balancing and Matching
    Balanced and matched shots make content from different cameras look consistent. You can use the auto balance tools to quickly balance a group of similar shots. Simply click the auto color button at the left of the color wheels palette to balance the shot’s color and contrast. You can also match the color between different shots. Select a clip, right click on another clip, and select “Shot Match to This Clip” from the menu. Resolve will match the color, contrast and brightness of the clip you’re working on with the one you’ve selected. If a shot contains a chip chart, click on the color match icon in the toolbar, select the type of chart used, line it up on the image and click match!
    https://www.blackmagicdesign.com/products/davinciresolve/color
